Add and Remove variable text
wbravenboer
Post by wbravenboer »
I created an action, adding variable text to a file (filename, ordernumber, date), this works great.
However, sometimes we need a reprint of the same file, so the ordernumber changes.
Is there a way to do this with pitstop? So to remove the added text.
In QuiteImposing the 'add text' 'remembers' the text and can undo it.
jslater
Re: Add and Remove variable text
Post by jslater »
We do something similar, and my solution was to put the text on its own layer. The action list first looks for that layer, removes anything in it, then adds the new information and places it back in that layer.
If your order number is unique, you may as well use the "Find and replace text" Action.
Screenshot 2026-02-03 at 14.34.14.png (21.19 KiB) Viewed 3722 times
There is otherwise indeed many ways for "selecting" the object:
- put on layer as suggested
- select by region, select text segments AND
- select by attributes (color, font size…)
