Just make my Canva PDF work! v3
Hey there,
I am working on a revised version of the Preflight Profile for fixing CANVA PDF files with the following additional fixes:
- Remove Transparency Group Settings to a page when no transparent objects is found onto the page
- Remove Transparency Group Settings to a Form when no transparent objects is found inside the form
- Remove completely transparent objects (0% alpha fill - No stroke, no fill - 0% alpha stroke, 0% alpha stroke and fill)
- Remove empty layers
- Consolidate fonts
- Remove concealed objects (i.e. objects which are completely obfuscated by overlaying page content)
- Remove unnecessary clipping masks
If you are facing problematic CANVA files in your production, would you mind give this one a try and provide feedback over this new version?
And any other possible improvements?
https://drive.google.com/file/d/1TAR6n4 ... drive_link
WARNING: you need PitStop 25.11 minimum to run it.
Thanks!
marek
Re: Just make my Canva PDF work! v3
Post by marek »
Hi
a file is unavailable:
This shared file or folder link has been removed or is unavailable to you.
DJS
Post by DJS »
Morning,
Any chance of making this available again, the v2 I currently use doesn't correct all canva files
Thank you
Daryl
Please try again the above link that I have updated and let me know if it helps more, or if it still needs improvements.
