Select region on only one page and remove selection
PrepressUnc
Post by PrepressUnc »
Hello all,
I'm doing variable data jobs and want to remove a specific text paragraph from only the second page for our static. This is going to be used on many similar but not the same jobs so I cant use select by key phrase(Unless I can select just a few reoccuring words and then expand my selection to nearby objects). Font also varies per job
I was using select by region however that applies to the entire document even if I try selecting page 2 beforehand. I know I can manually choose which page to run but I was hoping to combine this with a bunch of other steps into a singe click.
Any help would be appreciated.
Re: Select region on only one page and remove selection
select in region
select page 2
AND
remove selection
PrepressUnc
It worked! Thank you so much. I tried that before but had Select Pages BEFORE Select Region
