Check for visual content
DJS
Post by DJS »
Hello, I would like to check if a supplied PDF (for an infigo shop) has the content orientated correctly.
I have read that there is an action called, 'Check for visual content.' but this only checks for predefined items.
is checking if a page is upside down possible?
Re: Check for visual content
Depends what you call upside-down. If you mean a page that has a rotation key, yes you can select page which have a 180° rotate key and report.
If you have non rotated pages, but rotated content, there as well you could report (See "Select rotated objects" ).
If neither the page, nor the content is rotated but layout somehow looks rotated, then indeed there is no real ways to detect. You could use Check for visual content if there is a very peculiar content that you can detect upside down.
Unless someone comes with a better idea.
DJS
Post by DJS »
thank you.
