Frame masked objects with custom colors
yosimo
Post by yosimo »
I want to use an action list to outline masked objects with a rectangular spot color frame. The frame should align with the outermost, visible objects that have the spot color.
It works correctly on page 1 of my Test.pdf file. However, it doesn’t work on pages 2 or 3, even when I specifically select the spot color of the objects in question. I just can’t seem to get it to work.
How do I need to modify the action list to achieve this result?
Test-PDF
https://magentacloud.de/s/gt4aHoFexP5gLHp
PitStop-Aktionsliste
https://magentacloud.de/s/kyrDBCG6zppe2Ky
S1 properly masked and framed.png (34.31 KiB) Viewed 20040 times
S2 This is how it should look.png (36.6 KiB) Viewed 20040 times
yosimo
PitStop User
Re: Frame masked objects with custom colors
[EDIT] Eventually, there is a better option than the one previously proposed for two reasons. First, it's much simpler, second it's more respectful of the font license that prohibits outlining for that font.
The key feature here is the "Add trace path" Action.
So what you can do is:
- Select fill color
- Add trace path => will trace an object around the visible part of the foil object
- Select last added object => because tracing added a new object
- Save selection as "Trace path" => because we want to later remove it and saving selection will ease selecting those objects again.
- Resize art box to selection
- Add the "red" rectangle based on art box
- Restore selection "Trace path"
- Remove selection => to get rid of the traced objects
Screenshot 2026-07-01 at 21.35.20.png (179.09 KiB) Viewed 20030 times
yosimo
Post by yosimo »
Hi Loïc,
Thanks for your effort. Your solution works wonderfully.
I've shortened it a bit; I left out the sections #PROCESSING DUMMY TEXTS and #PROCESSING ANY DUMMY entirely.
Why are you using the “Change fill color to Dummy spot” action? I think the preceding “Remap spot color Hotfoil to Dummy” action already takes care of that.
It’s also strange - but in this case, it’s an advantage - that the “Select Spot Color” action selects not only the objects with the selected spot color but also the mask frames that clip those objects. I wasn’t aware of that.
Thank you very much,
kind regards
yosimo
P.S.: ohh, I just noticed that you've already shortened your suggestion 🙂
my actionlist.png (17.24 KiB) Viewed 20012 times
yosimo
PitStop User
Indeed, I late added "Remap" so that images would be covered making changing colors useless.
But anyway, you may indeed prefer the revised version which is far more direct.
Loic
yosimo
Post by yosimo »
The test PDF was created specifically for this request. I will monitor our clients' future print files to determine which version of the actionlists is more suitable.
yosimo
PitStop User
yosimo
Post by yosimo »
Hi Loïc,
so far, the action list has worked well.
But now I've received a similar file where the action list isn't producing the expected result.
https://magentacloud.de/s/K4HwQP6w4X2qFsD
The only difference I can see is that the text has now been converted to outlines.
Copying the hot-foil objects to the clipboard does not seem to take into account the cropping caused by the mask.
yosimo
PitStop User
Ok, for some reason the tracing behavior seems to vary based on if the blueish content is text or paths.
So I had to review the Action List. Maybe some simpler approach can be found. I will investigate internally.
All in all, it consists of both tracing the blueish content and then teh whole page content, then combine those traced paths to only get one that is really ncessary.
Again, happy to be challenged.
RedRectangleOverBlueContent.zip
(3.08 KiB) Downloaded 134 times
Screenshot 2026-10-14 at 10.58.08.png (72.6 KiB) Viewed 3363 times
yosimo
Post by yosimo »
Hi Loïc,
very interesting. I wasn't aware of this aspect of tracking objects and paths before. I'll look into it more closely and see how it applies to other similar types of data.
Thank you very much.
yosimo
PitStop User
