is there a way to Remove a named folder when this is processed through switch.
Example
3 subfolders
Folder 1 Removed
Folder 2 Not removed
Folder 3 Not removed
Remove a Folder In Switch
Re: Remove a Folder In Switch
Are these three subfolders in a job folder, or are they part of a hierarchy? Supposing they are in a job folder, are there always 3?
Basically this folder structure gets dropped into switch, its the same structure every time.
All switch does is find and replace the 6 digit job number at the begining of the file name.
Was Wondering if Switch could delete the folders called supplied and despatch and leave the rest as is.
- Screenshot 2026-08-12 at 15.13.46.png (226.61 KiB) Viewed 27280 times
I see two possible approaches.
Use the app "Delete files". For this to work the naming conventions of the files should be so that you can reliably delete the files that are in the "supplied" and "despatch" folders. The app has an option to delete empty folders so these folders will be removed if they become empty.
Use the app "Filetypes Counter" to count the number of folders in the job folder. Then dismantle the job one level deep ("Job dismantler") so you have all the folders separately. Divert the folders named "supplied" or "despatch" to the recycle bin and the others are regrouped with "Assemble job - Scheme:Custom" where "Number of files" is a Switch.Calculation of the private data with the number of folders minus 2.
Both apps are part of https://www0.enfocus.com/en/appstore/pr ... older-apps
Let us know which one worked for you.
Excellent thank you the 2nd suggestion worked for us
