Rename Filename
Charltonpaul
Rename Filename
Post by Charltonpaul »
Is there a way to rename a file after it has been merged together.
example
2 files - will always be 2 random named files
cover File. Always 4pp
Text File. Always more than 4pp
Then combined
So after it has been merged will want it renamed after the file that has more than 4pp
have tried private data but get different results
magnussandstrom
Re: Rename Filename
Post by magnussandstrom »
You can do it by applying a private data tag on only the file with more then 4 pages like this:
Charltonpaul
Re: Rename Filename
Hi Thanks for the info.
Cant get this to work, if I put 1 file through the flow it will rename it with the correct name.
If I put both through at the same time, it will not change the name at all.
Maybe my Assenble and rename file are incorrect.
Not sure if this matters, but the files before they are combined are renamed 1 and 2 so they are in the correct order
magnussandstrom
Re: Rename Filename
You probably got something wrong, here is a working flow.
name after file with more than 4 pages.zip
(54.8 KiB) Downloaded 1476 times
Charltonpaul
Re: Rename Filename
Thanks for your help. Much appreciated tweeked a few things in our flow. All good now
