InDesign and Universal Type Server
mkis
Post by mkis »
Hello everybody,
I have a problem with the InDesign CS6 configurator and the Universal Type Client in Switch.
The flow in switch should make a PDF from an InDesign Doc.
The UTC PlugIn in ID is activating the missing fonts, but the out fails, because switch means there are missing fonts.
Does someone have practical knowledge with this?
Thanks for your help!
Kind regards,
Michael
I have no practical experience with the Universal Type Client, but the Indesign configurator allows the use of a script to open a file, to do some processing on an open file, and to save the file.
I am pretty certain you can work around your problem by using an Indesign script, but I cannot tell at what point you would have to use it to make it work correctly with the UTC.
