Flow based of PDF file size
Posted: Mon Feb 23, 2015 10:25 am
by abonsey
When a PDF arrives in the input folder I want to flow the PDF based on its file size ie less than 10mb.
How do I do this? I see you can use calculation for a exact size but I want it based on <10mb.
Thanks for any help
Re: Flow based of PDF file size
Posted: Mon Feb 23, 2015 10:26 am
by gabrielp
pietdepauw wrote:When a PDF arrives in the input folder I want to flow the PDF based on its file size ie less than 10mb.
Thanks for any help
Set up your "include these jobs" criteria something like this:
There is no need to do a Switch.Calculation on [Job.ByteCount]. You can use it on its own in the left-hand side of the condition combined with "Less than - 10485760".
The alternative with a calculation would look like this:
[Switch.Calculation:Expression="([Job.ByteCount]/1024)/1024"] - Less than - 10
Posted: Mon Feb 23, 2015 10:27 am
by gabrielp
pietdepauw wrote:There is no need to do a Switch.Calculation on [Job.ByteCount]. You can use it on its own in the left-hand side of the condition combined with "Less than - 10485760".
Ah I see. I've seen that without the calculation sometimes number values do not show the less than or more than comparisons. Maybe that was fixed in an update.
by abonsey
Thanks for all the advice. Couldn't see the JobByteCount for looking!!
All working fine now.
