Check zones imbrication
I am struggling with one here I hop someone can enlight me. I have a PDF file with unconsistent zones. For example, the trim box is vertical when the mediabox is rotated at 90°. All I need here is detect those unconsistencies. I tried to check Pages secured areas but I can't get a setting that work perfectly.
Any ideas ?
TIA,
Loic
Re: Check zones imbrication
Post by abailescollins »
HI Loic
I think you need the Page Box Layout check in the Preflight profile for this.
It will check the page boxes and also you can specify distances between them, if this doesn't do want you want please let me know.
Hi Andrew,
Thanks for the input. Much appreciated. I did make a few attempts with this controller without obvious results. I will give this another try and let you know.
Best regards,
Loic Aigon
You can always send me the file Loic, happy to help if I can.
