SWITCH 10
SWITCH 10
Hi there!
Anyone who have any opinions regarding the new SWITCH 10?
I´ve installed the trialversion for test on my local machine and I think it loads a little bit faster than 9, but else it looks the same.
Want to hear about there is any common problems until we upgrade in production environment.
We have four licenses of PowerSWITCH 09, update 3 running.
Thanks!
/Henrik
Thanks!
/Henrik
SWITCH 10
Henros wrote: Hi there!
Thanks!
/Henrik
Henrik - I upgraded straight away (now on PowerSWITCH 10, update 2) - everything's been fine here...
Thanks!
/Henrik
SWITCH 10
Alas - I cannot give you a direct link Henrik - it's an update issued to us via our Maintenance contract, it comes from the Esko DL site - but you are correct, there doesn't appear to a download available...
SWITCH 10
Hi Clive,
there is no Switch 10, update 2 available, the most recent version released is Switch 10.
We are working on a Switch 10, update 1, but that one is not final yet.
Please feel free to contact us at support@enfocus.com if you have any questions!
Kind regards,
Carine
Kind regards,
Carine
SWITCH 10
Hi Clive,
Kind regards,
Carine
Kind regards,
Carine
SWITCH 10
Thanks Carine!
Is there any schedule for update 1 then?
We have som "small" requests for future releases:
- Include textboxes and symbols in the flow to make it easier to describe some functions for supportstaff.
- Manage the size of the elements in the flow (eg folders between "functions"). Will make it easier to overview the high priority folders-
- Turn off the calculating on folders (we have performanceproblems if there is more than 99 files in a folder and have a lot of such folders, eg for backup a few days)
- Format folders with colors (to make it easier to find starting and ending points in big flows)
/Henrik
/Henrik
SWITCH 10
My mistake - it's PitStop Server 10 update 2, not Power Switch
Initials are too similar for my meagre processing power...
SWITCH 10
I´m answering myself
Use the upgradefile!
EDIT
4 step installation:
1: Backup server & flows
2: Install Enfocus_PO_10_update1.exe
3: Activate your new license
4: Deactivate your old license with Local License Manager, http://www.enfocus.com/kb.php?id=7028
GO!
EDIT
GO!
SWITCH 10
Hi Tkittel!
Sorry I was to quick with this instruction.
We upgraded from PS 09, upd 3 to SWITCH 10.1
First I found out that I should deactivate PS09, but then the licencekey did´nt get activated correctly.
It is mandatory the 09 key is also activated on the same machine in order to have Switch fully licensed. This depending on your type of key of course, we had an upgrade key.
You can then manage all your licenses with Local License manager:
