SQL statement to update boolean field
Terkelsen
Post by Terkelsen » Fri Sep 11, 2020 2:09 pm
I'm using the database module of Switch to update an Access database, which works just fine. However, the database has a boolean field (a checkbox). Any idea what would be the sql statement to toggle that field?
UPDATE Webshop (Produktionsklar)
VALUES ('????')
jan_suhr
Re: SQL statement to update boolean field
Post by jan_suhr » Fri Sep 11, 2020 3:33 pm
Have you checked what's in the database field in the database.
Could it be True or False or maybe 1 or 0
Jan Suhr
Color Consult AB
Sweden
Check out my apps
Terkelsen
Post by Terkelsen » Wed Sep 16, 2020 10:19 am
Hi Jan,
Sorry for my late response.
These were my first thought too, but none of them seems to work.
jan_suhr
Post by jan_suhr » Wed Sep 16, 2020 10:28 am
Do you have any kind of database editor that you can access the Db directly and read what it says on that field?
Jan Suhr
Color Consult AB
Sweden
Check out my apps
Terkelsen
Post by Terkelsen » Fri Sep 18, 2020 11:31 am
Well, it turned out that 0 and 1 indeed were the triggers to use, so I finally got this statement to turn the check box on:
UPDATE Webshop
SET Produktionsklar=1
WHERE OrdreID='[Metadata.Text:Path="/Impleo_JobTransaction/TopOrderID",Dataset="Xml",Model="XML"]'
jan_suhr
Post by jan_suhr » Fri Sep 18, 2020 11:33 am
Great
Jan Suhr
Color Consult AB
Sweden
Check out my apps
