SQL statement to update boolean field
Terkelsen
Post by Terkelsen »
I'm using the database module of Switch to update an Access database, which works just fine. However, the database has a boolean field (a checkbox). Any idea what would be the sql statement to toggle that field?
UPDATE Webshop (Produktionsklar)
VALUES ('????')
Re: SQL statement to update boolean field
Have you checked what's in the database field in the database.
Could it be True or False or maybe 1 or 0
Terkelsen
Post by Terkelsen »
Hi Jan,
Sorry for my late response.
These were my first thought too, but none of them seems to work.
Do you have any kind of database editor that you can access the Db directly and read what it says on that field?
Terkelsen
Post by Terkelsen »
Well, it turned out that 0 and 1 indeed were the triggers to use, so I finally got this statement to turn the check box on:
UPDATE Webshop
SET Produktionsklar=1
WHERE OrdreID='[Metadata.Text:Path="/Impleo_JobTransaction/TopOrderID",Dataset="Xml",Model="XML"]'
Great
