Submit point and metadata
JimmyHartington
Post by JimmyHartington »
Hi
I have looked at the options for the submit point and metadata, but I can not find an option for a radio button with the option to choose more than one item.
Has anybody solved this somehow?
cedric.sintes
Re: Submit point and metadata
Post by cedric.sintes »
There is no radio button (unfortunately :cry: ). However, this possibility would be very useful (wink development team :roll: )
The only way is to propose the same drop-down list several times :oops:
Malcolm Mackenzie
Post by Malcolm Mackenzie »
You need to send it in as a feature request through your portal,
requests don't always get seen here.
https://www.enfocus.com/en/support/portal
Repeating the drop down list won't be that bad as in the xml you can then
give a unique name to the item
Item 1
Item 2
etc
jan_suhr
Post by jan_suhr »
You might be able to do it with the Rest API
Jan Suhr
Color Consult AB
Sweden
Check out my apps
JimmyHartington
Thanks for all the replies. I will submit at feature request.
