To be more specific. A CSV file is coming into the flow. I'm counting the number of rows in that CSV file and writing it into Private Data by using the app Count Rows. This file has to be sent to a specific folder, only when that folder holds a number of PDF-files that is equal to the number of rows in the CSV file.
If you set the HoldJob element property for Folder constraint to Yes, you are able to define a Maximum job count as a fixed number. I would like to be able to define an Exact job count and define it as a variable.
