CMYK image and "gray" image
Bakancsok
Post by Bakancsok »
Hi!
How do I distinguish between the two images?
Simple:
https://we.tl/t-DFUpKGy1w9
:oops: :oops:
bens
Re: CMYK image and "gray" image
Post by bens »
The action "Select by number of color plates" can help, if you turn colour management off. Unfortunately your "good" example does have some stray pixels that use more than just the K plate - very few, but enough to throw off the plate check. If possible I suggest you automatically fix these rather than trying to find them. The action "Select black and white objects" could help with that:
Convert color to gray
Override color management settings: color management OFF
Convert color to CMYK
Bakancsok
Post by Bakancsok »
Hello!
I don't want to convert the picture, just find it.
I've included a better example.
https://we.tl/t-uQ1pl7QqIq
bens wrote: Tue Jan 07, 2020 12:04 pm The action "Select by number of color plates" can help, if you turn colour management off. Unfortunately your "good" example does have some stray pixels that use more than just the K plate - very few, but enough to throw off the plate check. If possible I suggest you automatically fix these rather than trying to find them. The action "Select black and white objects" could help with that:
bens
Post by bens »
That one works perfectly with "Select by number of color plates".
Select if number of color plates is more than 1
Log selection "BAD"
Select if number of color plates is equal to 1
Log selection "GOOD"
If you want to make sure you don't get objects with e.g. only Cyan you can combine it with the "Select black and white objects" action:
AND
Log selection "BAD"
Bakancsok
Post by Bakancsok »
Thank you, this was a good solution. :D
