Hi All,
Within a flow I preflight a client PDF to ensure all the trim boxes are the same size. Client files continually fail as it would appear the client has added an additional blank page within Acrobat. This added page has no geometry set so my actions add to it.
Has anybody come across this and managed to build a flow/action to correctly identify these random pages and fix them?
TIA
Andrew
Added PDF blank page failure
abailescollins
Re: Added PDF blank page failure
You'd need to use the 'Select Empty Pages' Action Andrew
With this you can check only empty pages and build actions that check/fix only empty pages or exclude empty pages.
abc@imposition.com
abc@imposition.com
