Save as Optimised PDF from Adobe Acrobat Professional configurator
LasseThid
Post by LasseThid »
Does anyone know if it is possible to save a pdf file as an optimised pdf using the Adobe Acrobat Professional configurator?
I can't find any options for it, so I assume you would have to use a script to do it if it's possible, but how would you write the script to save the file as an optimised pdf with a specific setting in that case?
Malcolm Mackenzie
Re: Save as Optimised PDF from Adobe Acrobat Professional configurator
Post by Malcolm Mackenzie »
Hi Lasse
about 98% certain you can't.
You can combine PitStop cleanup and GhostScript.
GhostScript clears all overhead etc.
Malcolm
LasseThid
Post by LasseThid »
Thanks for the information.
We will use PitStop server then.
patej
Post by patej »
If you have (or can upgrade to) PitStop 2021 released last week, it has a new action list called "Optimize PDF (emulates Acrobat optimized save)" which should get you similar results than in Acrobat:
LasseThid
Post by LasseThid »
Thanks for the information patej.
I do have it, just haven't gotten around to install it. Now I really do have a reason to do it... :lol:
