Private Data in Metadata Path
Laurent D
Post by Laurent D »
Hello
Is it possible to integrate Private Data in a Metadata path.
I need to process multiple data in XML using a loop and I will want to use Private Data to increment the data to retrieve.
Example:
[Metadata.Text:Path="/Products/Product[1]/ProductName",Dataset="Xml",Model="XML"]
[Metadata.Text:Path="/Products/Product[[Job.PrivateData:Key="COUNTER"]]/ProductName",Dataset="Xml",Model="XML"]
Thank you for your help
laurentd
Re: Private Data in Metadata Path
Post by laurentd »
No, it is not possible, but the Variable XPath Repeater app does exactly what you need.
https://www.enfocus.com/en/appstore/pro ... able-xpath
Laurent D
Post by Laurent D »
Thank you for your reply. This solution seems very good to me, I will test it! :D
