Stored Color Swatches Inspector
Is there a way to remove or delete stored color swatches from the inspector?
abailescollins
Re: Stored Color Swatches Inspector
Actually I don't think there is actually a delete or remove as such.
The idea would be you just replace them with a new one, which of course could be white which is really the same thing.
Can you explain why you need it, I can then write it up as a feature request.
abc@imposition.com
abc@imposition.com
As I am a novice user, (not a graphics designer) I have several "versions" of the same color and it has become confusing as to which "version" I really need to use. Changing them to white is an alternate fix which I hadn't thought of, thank you for that idea and your response to my post.
abailescollins
Selecting them and hitting delete would be a nice improvement!
abc@imposition.com
abc@imposition.com
I cannot find a way to edit/change their appearance, once you store a swatch you're stuck with it
Create a new rectangle or select any line art in a PDF. Use the inspector to change its fill or stroke colour to white. Then click the swatch you want to remove so it is selected, and click the "Store Swatch" button.
And "viola" problem solved, thanks Bens!
