did anyone succeed in successfully creating JDF files for the Kodak Nexpress System? I'd like to have a configurator similar to the one the HP Indigo Division is supplying (which is limited in functionality but works for 90% of the use cases).
Or does anyone ever successfully created a working JDF template for Kodak Nexpress Systems?
Cheers,
Thorsten
Kodak Nexpress JDF Configurator
Apago has developed several JDF Switch Configurators. However, not yet for the Nexpress. I'd be happy to discuss the projects requirements with you.
currently starting a conversation with the Nexpress / Prinergy division on JDF requirements... if they are not cooperative i'll come back to you Dwight
I'm also looking for this. I have one contact how is going to look at this, to see if he can do a Configurator for the NexPress.
I have found the manuals for all jdf-code that NexPress uses. And with the test-file found inside NexPress front end we hope that we can get a solution..
But please, keep this tread updated if anyone gets closer to the goal.
Between jobs!
The HP Indigo JDF configurator can perform the following tasks:
copies, priority, destination, queue, duplex, collate, stacker, jog, facing, page order, media, color parameters, imposition template, banner and divider sheets and accounting info.
What functionality would you like to have in the NexPress JDF configurator?
Are there any JDF configurators for Xerxo iGen Freeflow RIPs? I have the Indigo ones configured and they work great. Having a lot more issues trying to send JDF to the Xeroxs.
