I have several flows using Inject Job. Oftentimes the job is not there to inject. Which is fine, my goal is to inject if it is there. Either condition is normal and expected - but I have no way of knowing before hand if the job to inject is there, or not.
The problem is when it isn't there, it goes to Problem Jobs. My solution thus far is to just direct them out of problem jobs into Recycle Bin.
This works, but isn't there some better way? My issue with my solution is I see all these errors in the log, but they aren't really errors.
Inject Job - dealing with failures
RunDontStop
Re: Inject Job - dealing with failures
Try the app Inject Wildcard, it might solve your problem.
https://www.enfocus.com/en/appstore/pro ... t-wildcard
RunDontStop
Thank you. I will look into this and see what I come up with.
