Acrobat fix for Pitstop
I just updated to the most recent version of Acrobat (Version 2022.001.20085) which was supposed to correct the contextual issue from the previous versions. Upon launching Pitstop, I am still not able to select and of the items and does not appear to have been fixed. I an currently running Pitstop Pro 2019. Any thoughts?
- john.dean@esko.com
Re: Acrobat fix for Pitstop
I will ask development about this. I am using version 2022 beta on macOS and the contextual menu seems to be working.
Somewhat familiar with Enfocus products.
When I select an object, it is not showing the points or selecting the object. It will still perform the function, but you redoing it blindly. That was what was happening to me before the fix which resulted in us having to roll back to a previous version. I thought the fix corrected that. That was the reason for me upgrading back to the current version.
CruzinCooler
This did the trick as all our Macs are operating as normal once again.john.dean@esko.com wrote: ↑Mon Mar 28, 2022 5:17 pm I will ask development about this. I am using version 2022 beta on macOS and the contextual menu seems to be working.
