This is a simple question I hope. You cannot define variables for a path using the Archive Hierarchy flow element.
I am on a Mac. When writing files to a network volume, the path always begins as:
/Volumes
I came up with a way to include variables with Archive Hierarchy. The element uses the path as described above.
Before the Archive Hierarchy, I assign variables in Set Hierarchy Path.
This seems to work well. My files go to the correct destination.
My question is: what is wrong with doing this, if anything? I don't see any issues, but that doesn't make this flow structure a good idea.
To further test, I set up a flow where the network volume did not exist. As expected, the job went into the problem jobs folder. It didn't cause a major problem or a system crash.
I am hesitant to move forward with this solution, because Archive Hierarchy does NOT have the define variables option, and so there must be some reason.
Consider the path:
/Volumes/Jobs
Jobs, as seen on the Mac, is not a folder, it is a mounted network volume. When using Archive Hierarchy, Switch normally creates any folders in the path that are not already there.
So if Archive Hierarchy path is:
/Volumes
And you have a private data tag "TOP", defined as "Jobs"
Set Hierarchy preceding Archive Hierarchy uses the variable "{Job.PrivateData:Key="TOP"]
When the job reaches the Archive Hierarchy element, Switch is attempting to write the file to:
/Volumes/Jobs
If the network volume "Jobs" is mounted, the file goes on into "Jobs" with no issue.
If "Jobs" is not mounted on the Mac, Switch cannot create a folder on the level "/Volumes" and so the job goes into Problem Jobs, which is good.
Any problems with what I have described?
Defining Variable for Archive Hierarchy
RunDontStop
- JimmyHartington
Re: Defining Variable for Archive Hierarchy
As I understand the use of the Archive Hierarchy, you need to set the basepath.
Jobs will then be archived with the hierarychy set on the job. Either a hiearchy set in the processing of the flow, from input or with the Set Hierarchy Path.
So in your case you should probably set the base folder in Path to "/Volumes/Jobs".
You can the use other mechanism in Switch to create your hierarchy.
- JimmyHartington
Here is an example from a flow, where I use the hierachy information to build a custom hiearchy.
On the folder images (and the other orange folders under it) I have set "Attach hierarchy info" to Yes.
And with "Set hierachy path" I use a variable (in this case private data) to set the top of the hierachy.
And with the base folder of "Archive hierarchy" set to path "/Volumes/Jobs" I get this hiearchy of images downloaded by the flow.
/Volumes/Jobs
├── SKU-ABC_
│ └── images
└── SKU-DEF_
└── images
