Preserve structure, delete content (Once a week)
senghaas
Post by senghaas »
Hello Switch colleagues,
I have a specific problem where I am looking for the most feasible solution.
A large amount of PDF is filtered through Switch once a week, renamed and placed in a folder structure.
If I create the folders as recycle bins and specify a standing time of 7 days, the Switch ID still comes before the file name. Users then wonder where the nonsensical file name comes from.
Is there a possibility that Switch deletes the folder structure once a week at a fixed time?
The folders themselves should remain - only the PDF should be moved to the trash.
I would be very grateful for any further tips.
laurentd
Re: Preserve structure, delete content (Once a week)
Post by laurentd »
You can use 2 apps for that:
• File pool cleanup, part of the Folder Apps bundle.
Inject Wildcard
With both apps you can delete the files only and keep the folders.
You can also use time filters, to only delete files older than 7 days.
I don't see the complete flow, but you can send the files to sub folders in a dynamic way, using a variable, with less icons:
[Job.NameProper:Case="upper",Segment="1-1"]_
first letter.png (11.9 KiB) Viewed 4094 times
senghaas
Post by senghaas »
Hi Laurent,
thank you for your suggestion! The first thing I tried was the order by hierarchy. That worked great right away. Unfortunately I can't download the apps "Inject Wildcard" and "Folder Apps". I have therefore informed the support. Many thanks for this tip!
As soon as I have the functions available, I'll get back to you.
Thanks again and best regards, Jürgen
