HTML-table as variable in HTML-mail?
magnussandstrom
Post by magnussandstrom »
Hi!
I have a (variable) html table (as a html file) that I want to embed as a part of a html email in Switch. The email html has other Switch variables in it, but I can't figure out how to embed my table. Any suggestions?
ps. I also have the table as a CSV if that can be used some how.
Re: HTML-table as variable in HTML-mail?
Put the HTML of the table in private data and place that variable in your HTML template.
magnussandstrom
freddyp wrote: Tue Nov 29, 2022 9:11 am Put the HTML of the table in private data and place that variable in your HTML template.
Any suggestion how? The HTML-table is a file, not metadata.
JimmyHartington
Post by JimmyHartington »
Could you read it in as Privatedata.
I have not tested it, but I think the "Create file from template" app can insert a file into a file.
JimmyHartington
I have this legacy script-code I have used earlier.
  This script reads the body of a file to private data.
	// Set some property stuff
	if(s.getPropertyValue('Debug') == 'Yes'){
		var debug = true;
	} else {
		var debug = false;
	if(job.isFile())
		// Make temp file
		var htmlData = File.read(job.getPath(), "UTF-8");
		// Set to PD
		job.setPrivateData("text", htmlData);
		// Debug
		s.log(1, 'TXT: ' + htmlData);
		// Send along
	} else {
		// Not supporting folders
		if(debug) s.log(2, 'Input job was folder.');
magnussandstrom
Thanks Jimmy, but unfortunatly I do not have the scripting module.
What I need is to just copy the text from the html-file and insert as PrivateData, but maybe thats not possible without the scripting module?
Maybe someone can build the app: 'Text file 2 PrivateData'
Padawan
Post by Padawan »
Are you on windows or mac?
magnussandstrom
Padawan wrote: Wed Nov 30, 2022 10:27 pm Are you on windows or mac?
Windows
Padawan
Post by Padawan »
You can use the "Run Command" App to achieve this. You can use either Cmd or PowerShell:
In Cmd using the type command:
Screenshot 2022-12-01 at 08.46.58.png (46.56 KiB) Viewed 22492 times
In powershell using the Get-Content command:
Screenshot 2022-12-01 at 08.47.06.png (46.55 KiB) Viewed 22492 times
The path to the text file can be set via variables of course. The content will be in the FileContent Private Data field.
JimmyHartington
Padawan wrote: Thu Dec 01, 2022 8:49 am You can use the "Run Command" App to achieve this. You can use either Cmd or PowerShell:
This was a clever way to do it. :D
Padawan
Post by Padawan »
Thanks! The solution is not very elegant, but it works :)
magnussandstrom
Thanks, it works great!
I ended up using Command Promt and command:
type "%%InputFilePath%%"
Shawn_Anderson
Post by Shawn_Anderson »
Yeah the Run Command app is great for parsing text files into private data. I use these on the Mac in the zsh shell all the time
to read all the text
cat %%InputFilePath%%
to read just the first line
head -1 %%InputFilePath%%
to read everything after the first line
tail -n +2 "%%InputFilePath%%"
to read lines that contain the string 'keyword'
awk '/keyword/{print}' "%%InputFilePath%%"
