How to make an Action List for Step and Reapet work
Allen M
Post by Allen M »
Hello all.....
I have a problem that I haven't been able to make an Action List for working on the step and Reapet files...
May I be helped to make the Action List...
Sincerely and Thank you
CruzinCooler
Re: How to make an Action List for Step and Reapet work
Post by CruzinCooler »
Go the the Category "ADD" from the Standard set installed in the action list. Look for: Add Enfocus Background and configure it to your needs.
Allen M
Post by Allen M »
Thank you for reading my complaint....
May I ask for Action list that has been made to you....
I will be very happy if you are given a ready-made action list so I can learn more...
CruzinCooler
Too many variables to make a generic action as the action already works. It's just not to step & repeat as set. Edit the action, or double click it to edit and go to the Repeat tab and configure it according to your needs. You would need to post a PDF with what you want repeated and the values that they need to repeat.
Screen Shot 2023-02-02 at 11.32.08 AM.jpg (185.01 KiB) Viewed 24773 times
Gearstudios
Post by Gearstudios »
Was bored one day and made this step and repeat for Pitstop pro. Need to import the variable set then select the variable set for this to work. It’s setup to impose on a press sheet measuring 29.5”x20.75”. I can modify the action to add the ability to input any press sheet size or create a list of common sheet sizes. Download and give it a try.
https://www.dropbox.com/scl/fi/ktfhw58s ... b8auo&dl=0
