I was wondering if there was a way to change the custom report's color chapter to only show spot colors.
Or if that is not possible to create a check that would report the names of all the spot colors used in a document.
Custom Reports - Spot Colors Only
Malcolm Mackenzie
Re: Custom Reports - Spot Colors Only
Hi
You can use a Preflight profile and from the Color tab select Spot color as per the grab.
The colour chapter contains the information gathered by the "Gather color information" chapter. Like all actions, this will work on selected objects only. When used in a Preflight Profile it will select everything, and hence you'll get all the colour information. But you can use it in an Action List as well, and then restrict it to any selection you want.
In other words: create an Action List that does "Select spot color" + "Gather color information". If you want this in a Preflight Profile you can add it to the "Checks" of the embedded Action Lists. Be sure to disable the "Color" checkbox on the general tab if you do that.
Thanks Everyone!
I got that modified and it worked perfectly.
Ok, now I have another question in the same realm.
If I only wanted the page boxes page to show the trim, bleed and crop boxes is there a way to do that?
Hmm I don't think that is possible, sorry. You could try logging a feature request.
@jcarden,
Why would you want NOT to display the mediabox and DO want the crop box. For the latter, it's only useful for applications that display PDF files. And the mediabox is normally something you would want to have for info.
Feel free to give a practical example here.
Loic Aigon
Loic Aigon
@loic-
The real problem here is that there is too much information for our CSRs. In our workflow they just need to care about the Trim & Bleed box sizes.
When I send the report to them now most of them get confused by which box to pay attention too. I would really like to only show a limited selection.
- Screenshot 2023-06-26 at 10.15.40 AM.jpg (137.78 KiB) Viewed 24836 times
I see. A possible workaround is to create a custom template and set color for Mediabox and Artbox to white, but not pretty:
https://enfocus.my.site.com/customers/s ... 00000saDxe
Loic Aigon
Loic Aigon
