I'm trying to customise the report message, does anyone know if there is a list of possible variables.
The default is message for checking page size is '%BoxType% width is %Width%, should be %WidthComparator% %RequiredWidth%'
I made the assumption that there would also be height variables %HeightComparator% %RequiredHeight%' but get the results below.
Your supplied artwork Trim box width is 89.99978 mm, and height is <MISSING VALUE!!> and does not
match the quote size of equal to 86 mm - <MISSING VALUE!!> <MISSING VALUE!!> (2x on pages 1-2)
Customising Preflight Report Message Variables
- Preflight message
- 2022-01-06_17-13-51.png (27.13 KiB) Viewed 21715 times
Re: Customising Preflight Report Message Variables
When you have the Customize Report Message window open, if you click the arrows on the bottom of the window it'll go through the different variations of the report messages that are available and you can edit each one to have a custom message:
https://gyazo.com/ff345b98860cd6f8be0aa4b3d130249e
For the Check page size action the last message is the one that has the variables you were wanting to access
Thanks @mkayyyy. That worked!
By using the arrows at the window's base, you can cycle through the various report message options and personalize the text for each one. drift hunters
