Adding Page Dimensions at the end of a file name
Charltonpaul
Post by Charltonpaul »
I have created a flow where it adds the trim box dimensions at the end of the file, but it adds them in Points. Is there a way so it can adds millimeters instead.
jan_suhr
Re: Adding Page Dimensions at the end of a file name
Post by jan_suhr »
You have to use Switch Calculations to convert it to mm. Multiply with 0.352778
Jan Suhr
Color Consult AB
Sweden
Check out my apps
magnussandstrom
Post by magnussandstrom »
Suggestion:
[Switch.Calculation:Expression="round([Switch.Calculation:Expression="[Stats.TrimBoxWidth:Type="Effective"]/2.83464567"])"]x[Switch.Calculation:Expression="round([Switch.Calculation:Expression="[Stats.TrimBoxHeight:Type="Effective"]/2.83464567"])"]
JimmyHartington
Post by JimmyHartington »
In the Pitstop configurator you can also set it to create a report (which you do not need to use), and then you can change the unit.
A feature request for the configurator could be the ability to set the unit, without needing to create the report. But maybe there are some technical reasons for it.
JimmyHartington
I will just add that my action list uses the built in variable in Pitstop to get the size of the Trim Box.
So not a Switch variable.
rhd_ole
Post by rhd_ole »
I'll add in another suggestion, using FastLane from Pisttop, it will just provide you with any of the box sizes needed, Bleed, Trim, Media, ect. No calculation needed.
