Outgoing Connection path in javascript.
sgeller
Post by sgeller »
Is there a way to get the path for an outgoing connection?
I've been able to use s.getOutConnections().getItem(0).getFolderName() to get the name of the folder, but can't seem to find a way to get a full path for the folder.
TOP CONTRIBUTOR
Post by dkelly »
Both Connection and Occurrence classes only provide the folder name as displayed on the canvas. Not the directory path.
TOP CONTRIBUTOR
Post by dkelly »
Hack warning!
var myFlowName = s.getFlowName();
var myElementName = s.getElementName();
var outgoingConnectionID = s.getOutConnections().getItem(0).getElementID();
var switchFlowsDir = "/Users/dkelly/Library/Application Support/Enfocus/Switch Server/flows";
var pathDir = "";
var flowDir = new Dir(switchFlowsDir);
var flowEntries = flowDir.entryList("*.xml", Dir.Files, Dir.Name);
for (var i=0; i<flowEntries.length; i++) {
var xmlDoc = new Document(switchFlowsDir + "/" + flowEntries);
// find the flow
var flowName = xmlDoc.evalToString("//Header/Fields/Name");
if (flowName == myFlowName) {
// find the connection
var connectionNode = xmlDoc.evalToNode("//Object[@Class="connection" and @Id=""+outgoingConnectionID+]");
var outgoingFolderID = connectionNode.evalToString("./Fields/Destobject");
// find the folder element
var folderNode = xmlDoc.evalToNode("//Object[@Class="object" and @Id=""+outgoingFolderID+]");
pathDir = folderNode.evalToString("./Fields/Path");
break;
delete xmlDoc;
delete flowDir;
if (pathDir.length)
s.log(1, "output folder: " + pathDir);
else
s.log(3, "Could not locate output folder for flow " + myFlowName + " and connection " + outgoingConnectionID);
