insert file's tittle as metada in pdf
mcolmenero
Post by mcolmenero »
I want to insert the file's title in the pdf file as metada, through javascript or script with acrobat professional.
Is this possible?
Thank for your help
Best regards
The easiest solution is to do that with a PitStop Server Action List. You need just one action: Change document info. In the options you set it to change the title and select %Current Document Name% from the list of variables. If you need more flexibility in building the string you can enable the use of variables for the text field and use the Smart Preflight functionality.
mcolmenero
Hi Freddy,
Thanks for you help.
I try to put like you say me, but I can´t find the action "change document info"or similar. I try to put set personal info:yes, and then I put here the diferent variable (username, filename and useremail), but it doesn´t gone.
I have pitstop server 11 and Acrobat Professional 9.
I try to make a script (js) like this: script element.
this.info.author = "my name";
this.info.copyright = "Copyright xA9" + this.modDate.getFullYear() + " by "+ identity.corporation;
this.info.subject = "tests";
But when Acrobat professinal open, send me a internal error, and it doesn't gone neither.
Finally a I tried to make by console with ExifTool, and it gone, but I don´t know how to call a console command in switch and pass some variable. I don´t know to make this with javascript.
Best regards
Miguel Colmenero
Look again: it is in the section "Metadata". Or when you filter on "document" it is the third action.
TOP CONTRIBUTOR
Post by dkelly »
I created this configurator for a Switch user last year. It uses exiftool to set up to 4 metadata variables.
https://www.dropbox.com/s/vg92nplom7dd9 ... ol.sscript
To set the author from Submit Point metadata you could set one of the properties to:
Author=[Metadata.Text:Path="/field-list/field[1]/value",Dataset="Submit",Model="XML"]
Here's a list of metadata names for PDF format.
http://www.sno.phy.queensu.ca/~phil/exi ... s/PDF.html
Dwight Kelly
Apago, Inc.
mcolmenero
Hi Freddy and Kelly,
The first, thank for your help.
For Freddy, I attachment capture-screen of my PitSoptSever, because a I can´t find it, sorry.
Link where there is capture-screen
For Kelly,
Thanks for you script, I try to put gone, but I don´t know what put in filed1 to field 4. I try to put:
Field1: the path of where it is exiftool.exe
Field2 to fiel3, I put the name file, date and extension.
And switch answer:
Failed to run external process: C:/Documents and Settings/admin/Application Data/Enfocus/Switch Server/backing/New flow/automanaged/Folder 1/_00JYQ_00018-prueba00006.pdf -o C:/Documents and Settings/admin/Application Data/Enfocus/Switch Server/temp/41/ScriptElement/12/4/00018-prueba00006.pdf -F:Script Otz flujos newexiftool.exe -2013-12-17T09:44:52.890Z -pdf -True
What I need to put in this field?
Best regards
Miguel
TOP CONTRIBUTOR
Post by dkelly »
You will need to install Exiftool first.
Here are the download links:
Windows: http://www.sno.phy.queensu.ca/~phil/exi ... l-9.44.zip
OS X: http://www.sno.phy.queensu.ca/~phil/exi ... l-9.44.dmg
The properties "field1" to "field4" are where you set the metadata values you want to insert into the file. I provided an example above.
mcolmenero
Hi Kelly,
I have installed, but only it is a execute files.
I put inside program files and this the log from switch:
exiftool failed!
Failed to run external process: C:/Documents and Settings/admin/Application Data/Enfocus/Switch Server/backing/New flow/automanaged/Folder 1/_00JYW_prueba00006.pdf -o C:/Documents and Settings/admin/Application Data/Enfocus/Switch Server/temp/41/ScriptElement/12/31/prueba00006.pdf -F:Script Otz flujos newexiftool.exe -PDF:Author:prueba00006.pdf -PDF:Title:33800 -C:/Documents and Settings/admin/Application Data/Enfocus/Switch Server/backing/New flow/automanaged/Folder 1/_00JYW_prueba00006.pdf
I don´t know what I do bad.
See you
TOP CONTRIBUTOR
Post by dkelly »
You could simply copy Exiftool.exe to C:Windows or contact me for assistance
Evan
Post by Evan »
You may try this in the command section of Acrobat Configurator. You have to use "$doc" instead of "this". This will put the document filename into the "Title" document info. You can create additional metadata just by changing "Title" by something else.
If you want just the filename without the unique ID prefix you have to put the job filename proper into the argument 1 of Acrobat configurator and use $arg1 instead.
Ex. $doc.info.MyCustomTitle = $arg1
Use $arg1, $arg2, $arg3, $arg4, $arg5 to pass variable to acrobat
$doc is your current PDF
$error will log error to switch
try{
$doc.info.Title = $doc.documentFileName
catch(theError)
$error = theError
}[/code]
This is a late (holidays) reply to comment 6 with the link to the screen captures: the screenshots show the list of available Action Lists in Switch. In comment 2 I was referring to the building of an Action List yourself in PitStop Pro.
It will require that you know how to work with Smart Preflight variables in PitStop and Switch. There is the documentation and you will find some videos on youtube: search for "pitstop smart preflight".
mcolmenero
Finally y resolve with exiftool, thanks all people, for help me.
I leave the script for somebody need it.
See you
var args3 = job.createPathWithExtension(job.getExtension(), false);
var metadato1 = s.getPropertyValue("field1" );//take the filename
var metadato2 = s.getPropertyValue("field2" );//take user to send it
var metadato3 = s.getPropertyValue("field3" );//take the name of company
var String befehl = "C:/WINDOWS/exiftool.exe";// take the path where it is the program installed
var archivo=job.getPath();
metadato1="-title="+metadato1 + " -author="+metadato2 + " -subject="+metadato3;
befehl=befehl+ ' ' + metadato1 +' -overwrite_original "'+archivo+'"';
var exitStatus =Process.execute(befehl);
if ((exitStatus == 0) ||(exitStatus == 1)) {
return;
jonasy
Post by jonasy »
There is also a method to update existing xmp fields in Switch without external applications: you can do so using the XMP Inject tool.
If you setup the "Action" property of the tool to "Update XMP", then you can set different rules to update the xmp metadata. Changing the title field can be done like this:
XMP location path: dc:title
New value: The new title you wish to give to the PDF file (This can be a static text, single line text with variables or a script expression).
Value type: Localized text
Generic language: (leave empty)
Specific language: x-default
