Declare string variables, get a variable from private data, and join
cwswitch
Post by cwswitch »
I am very behind with converting to Node :?
Can some kind person help me see how I would do the following in Node, please?
var OpenSection = '[Metadata.Text:Dataset="Xml",Model="XML",Path="/Job/Something[';
var SectionKey = job.getVariableAsString("[Job.PrivateData:Key=\"sKey\"]");
var CloseSection = ']/Key"]';
var SectionData = OpenSection+SectionKey+CloseSection;
var SectionFinder = job.getVariableAsString(SectionData);
SectionFinder;
It basically writes a path from /Job/Something + A private data value + the rest of the path
I hope that seeing an example will help me greatly as I'm up against too many walls at once right now.
Issues I face.
1) my first Node so getting started at all
2) getVariableAsString is not supported and I do not see much (I can understand) that helps me
3) I begin to find it hard to see my screen through my tears
cwswitch
Re: Declare string variables, get a variable from private data, and join
Post by cwswitch »
I have got this far today by following the tutorial then reading a lot. I am one step from glory, so still looking for help
async function jobArrived(s: Switch, flowElement: FlowElement, job: Job) {
    let a:string = '[Metadata.Text:Dataset="Xml",Model="XML",Path="/Job/Something[';
    let b:string = (await job.getPrivateData("sKey"));
    let c:string = ']/Key"]';
    let d:string = a+b+c;
    let SectionFinder = ****I'm Stuck Here****
    await job.log(LogLevel.Info, `a is '${a}'`);
    await job.log(LogLevel.Info, `b is '${b}'`);
    await job.log(LogLevel.Info, `c is '${c}'`);
    await job.log(LogLevel.Info, `d is '${d}'`);
I'm stuck on the bit that in Legacy was
var SectionFinder = job.getVariableAsString(d);
SectionFinder;
Which would ask Switch to give me the value at the path "d"
tdeschampsBluewest
Post by tdeschampsBluewest »
Hi there,
Sadly there is no replacement for "job.getVariableAsString" in nodeJS, and we lost some "easy" way to grab info from switch.
To gather data trough an Xpath, you'll need this function :
async function getXpath(job: Job, dataset: string, xpath: string): Promise<string> {
	let result: string | number | boolean;
	try {
		const datasetPath = await job.getDataset(dataset, AccessLevel.ReadOnly);
		const XML = XmlDocument.open(datasetPath);
		const NSmap = XML.getDefaultNSMap();
		const evaluation = XML.evaluate(`string(${xpath})`, NSmap);
		result = evaluation;
	} catch (e) {
		result = e.message;
	return result.toString();
I also strongly suggest you to use template string with "backtick", when you need to "insert" something in a string, it's way more readable :
    const sectionKey = "something"
    const xPath = `/Job/Something[${sectionKey}]/Key`
Everything put together will result in something like this :
	try {
	} catch (e) {
		result = e.message;
async function calculateScriptExpression(s: Switch, flowElement: FlowElement, job: Job): Promise<string> {
    const dataset = "Xml";
    const sectionKey = await job.getPrivateData('\"sKey\"]');
    const result = await getXpath(job, dataset, xPath);
    return result;
Let us know if it work!
cwswitch
Post by cwswitch »
A few things tdeschampsBluewest,
1) many many thanks for the notes and examples! I could hug you. Some things are beginning to make sense.
2) it did not work out of the box, which is good as it has left me learning.
3) I was able to make a script expression work with an app, which was cool.
4) I am still unable to bring things together to make an actual script. I believe I need an entry point. I cannot see how to call these functions from elsewhere in the script or how to arrange things at all.
I got lost down a few holes today and progressed some more training, but it still did not click.
5) Thanks again :D
tdeschampsBluewest
Hi again!
For an app, the entrypoint is not the same, and the output should/will be different.
In a script expression, you always "return" something.
In an App, you'll need to store the result in a way switch will be able to read it afterwhile.
	try {
	} catch (e) {
		result = e.message;
    const dataset = await flowElement.getPropertyStringValue("datasetName"); //"Xml"
    const xPath = `/Job/Something[${sectionKey}]/Key`;
    const newPrivateDataName = await flowElement.getPropertyStringValue("newPrivateDataName") as string; //"My Private data"
    await job.setPrivateData(newPrivateDataName, result);
    await job.sendToSingle();
Do not forget to "transpile" your Typescript, if you work with an app. The command line should be :
SwitchScriptTool.exe --transpile PathToYourTypscriptFolder
If you work with VS code, you can automate this, with runOnSave (emerald walk) addon and by adding thoses value in your settings.json :
    "emeraldwalk.runonsave": {
        "autoClearConsole": false,
        "commands": [
                "match": "\\.ts$",
                "cmd": "cd ${fileDirname}"
                "match": "\\.ts$",
                "cmd": "SwitchScriptTool.exe --transpile ${fileDirname}"
cwswitch
Post by cwswitch »
Awesome tips. Thanks so much for the hand holding :D very much appreciate your time.
I will go into a darkened room for a while and let you know how I go...
cwswitch
Post by cwswitch »
Party time at my house!
In a way you did hand me the solution, thanks for that.
I did though do lots more in the background to get this where it needed to be, and mainly, I understood the code and was able to work with it.
Many thanks for the help here.
