Unable to read the command: ScriptedFlowElement::jobArrived
PaulHough
Post by PaulHough »
I am not sure why i am getting this error can anyone help?
I am running a really simple script so i dont see what the issue could be.
Script:
var var1 = job.getNameProper.lenght()
if (var1 != 21){
if (var1 != 20){
Job.NameProper = "0000000_Form0000FB__T";
There are several things wrong with the script:
- lenght is not correct, it has to be length
- Job is not correct, the variable is job
- it seems like you are trying to do something that belongs in a script expression of one of the actions of the "Rename job" element, but you are handling it like a script element.
- I do not know what you are trying to achieve, but I think you will need some else statements as well or you are going to end up with an empty string.
Because of the first two problems the function is not available which is why you get that error message.
TOP CONTRIBUTOR
Post by dkelly »
maybe something like:
var name = job.getNameProper();
var var1 = name.length;
if (var1 < 20 || var1 > 21){
name = "0000000_Form0000FB__T";
job.sendToSingle(name);
It would have to be:
job.sendToSingle(job.getPath(),name);
the first parameter being the path of the file that is passed on and the second its optional new name.
As a script expression on a rename action it would be:
if (var1 21){
else {
name;
TOP CONTRIBUTOR
Post by dkelly »
oops, Freddy is right.
Re: Unable to read the command: ScriptedFlowElement::jobArrived
Post by gabrielp »
Just in case anyone else stumbles upon this in the future. The "Unable to read the command: ScriptedFlowElement::jobArrived" error message means the script instance has crashed. You can reproduce this my making a script in scripter which crashes, then trying to run it in Switch. Lots of things cause scripts to crash, but a common one is declaring variables inside of the scope of another function.
