I have a flow that will reach out and grab a folder from a location and injects it into a flow via metadata.
	What i need is;
	if (folder exists){current code}
	else {send email}.
	I have tried the job.getFileCount() but I couldn't retrieve a value with a location path.
	Any suggestions would be helpful.
	Thanks,
	PH
	var JobNumber = job.getVariableAsString('[Metadata.Text:Path="/field-list/field[2]/field-list/field/value",Dataset="Submit",Model="XML"]');
	var theSourcePath = job.createPathWithName( JobNumber );
	s.copy( "/Users/prinergy/Desktop/Fake jobs/"+JobNumber, theSourcePath );
	job.sendToSingle( theSourcePath );
	job.sendToNull( job.getPath() );
	s.log(1,JobNumber);
						Testing to see if a folder exists in a location
You can't send an email directly from a script. You will have to set the email variables and send it using an Email Send element in you flow.
var folderName = "/Users/prinergy/Desktop/Fake jobs/"+JobNumber;
if (File.exists(folderName)) {
s.copy( folderName, theSourcePath );
s.log(1,JobNumber);
} else {
s.log(1,"Folder " + folderName + " does not exist");
s.log(1,JobNumber);
} else {
Do i have to declare File as a Var?
Thanks,
PH
						Thanks,
PH
no, because File.exists() is a static function.
Is there a site that lists all of the static function?
Thanks,
Paul hough
						Thanks,
Paul hough
No, you have to review the Javascript documentation for each class. It will list the static functions.
http://www.enfocus.com/Manuals/UserGuid ... S/home.htm
Thanks for your help
PH
						PH
