Thank you for this forum.
Sorry if this question has already been asked but I don't find any simple solution here or in the Switch Guide.
After a split PDF app, I use the RenameJob app with this "Single line with variable" :
[Job.PrivateData:Key="theCode"]_[Stats.PageLabels]_[Job.PrivateData:Key="stringAfterPages"]
I need 3 digits in the PageLabels number (no pdf with more than 999 pages !) but don't find formating options for numbers...
Is there a switch fonction for formating numbers in a "Single line with variable" like it exists for dates :
[Switch.Date:TimeZone="UTC",Format="yyyy-MM-dd"]
Thank you very much for your help
AF
Formating numbers rules for PageLabels
- tdeschamps
Re: Formating numbers rules for PageLabels
Hi AF,
In the Split PDF tool, you can actually do this automatically no need to use a Rename Job after!
In the Prefix / Suffix properties, you can set up some built-in variables. They add the correct number of leading 0 as needed.
Note that other variables like Private Data do not work in those properties.
Here’s a quote from the documentation:
In addition, if you want to add leading 0 for some other case (or if you have two digit pdf, and always want it on 3 digit), you can use the rename action "Add leading 0", you'll just need a regex to catch the correct pattern, in this case something like ^\d+
So basically, in your case, use [Label]_ as a prefix in the Split PDF tool, then use a Rename Job (if needed) to add a second prefix with [Job.PrivateData:Key="theCode"]_[Index] The one-based index (in the original file) of the first page stored in this result file.
[LastIndex] The one-based index (in the original file) of the last page stored in this result file.
[Label] The PDF page label of the first page stored in this result file. If the page does not have a label, its one-based index is used.
[LastLabel] The PDF page label of the last page stored in this result file. If the page does not have a label, its one-based index is used.
[LastSourceLabel] The PDF page label of the last page in the original file. If the page does not have a label, its one-based index is used.
[Total] The total number of pages in the original file.
Bonjour Thierry,
thank you for your answer.
The original file name contains the first and last pages numbers in the middle of the name, and I want to remove this information from the renamed PDFs
So, I split pages of a multipages PDF then I rename each pages because I need to keep only the Label with specific Private Datas as prefix and suffix.
I need practice because it's not as simple as I thought.
I thought a calculation was possible and might be enough. For example, concatenate "000" and PageLabels while keeping only the last 3 characters...
And to use this calculation in the Rename Job with Variables.
I need training... The split Pages is not really clear at all for me...
Thank you !
AF
Thank you !
AF
