invert selection and convert to gray
multiprint
Post by multiprint »
I'm trying to make an action list that starts with a dialogue box so i can enter a page range. Afterwards the actionlist adds bookmarks to the page range. so far everything is going according to plan but then i want pitstop to select all pages but the ones with the bookmarks and convert them to gray but that doen't happen. What did i do wrong? I think i'm missing something. Could anyone help?
- Select pages (using variable set)
- add bookmarks
- select all pages
- NOT
- Select Pages with bookmarks
- convert color to gray
loicaigon
Re: invert selection and convert to gray
Post by loicaigon »
I think that your only problem is that you want to go backward, converting pages to gray after bookmarks were crated.
If you use Split Action List, this should work. By the way, I think you are overcomplicating things but that may be due to your experiments.
Here is what you can do:
- add bookmarks
- Split Action List
That should then work.
multiprint
loicaigon wrote: Tue Dec 02, 2025 9:03 pm Hi,
- add bookmarks
- Split Action List
Hi Loic,
Thanks for your reply !!!
i don't understand what you mean with the split action list. We use split to split pdf's that are sent as spreads. I don't understand how this action will solve my problem. i dont want to convert the bookmarked pages to gray but the ones except the bookmarked ones. The pagerange that is entered in the field are the ones that need to remain in color. So my solution was to bookmark the pages that need to remain in color and then select all pages NOT select the bookmarked ones to end up with the right selection.
loicaigon
Post by loicaigon »
Hi
Then
- add bookmarks
- Split Action List
- NOT
- Select Pages - All
- AND
You need the Split Action List to start over from Page 1 so that added bookmarks can be taken into consideration.
multiprint
Hi Loic,
Thanks a lot, your explanation solved the problem !
CruzinCooler
Post by CruzinCooler »
Can you or someone please show me Step-1 on how you select a page range utilizing a dialog box? (using variable text)
I would greatly appreciate it. I can't seem to get a handle on this. Thank you.
CruzinCooler wrote: Thu Dec 04, 2025 6:09 pm Can you or someone please show me Step-1 on how you select a page range utilizing a dialog box? (using variable text)
https://learning.enfocus.com/course/view.php?id=54
CruzinCooler
freddyp wrote: Fri Dec 05, 2025 11:04 am
Thank you freddyp but I'm unsure how to select a page range, I've seen the video but I am missing something with the page range option.
Thanks again
In the "Select pages" Action you choose "page range" from the dropdown and make the page range field variable. The value to be filled in is a string that looks like this: 1-4,10,20-30,40-R5.
