Action as part of a Quick Run differs
wbravenboer
Post by wbravenboer »
I made an Action to create Dots for our Zund Cutter, this also became part of a QuickRun I use to create several actions.
Now I made some changes in the Action for the Dot positions. But when I used this is in the QuickRun the older action was used!
After removing the 'older' action, and replacing it with the 'new' action (same name as the first one), the dots were correctly placed.
In short, the action used in the QuickRun was different than the separate saved one.
loicaigon
Re: Action as part of a Quick Run differs
Post by loicaigon »
Yes, that's how it works presently so what you had was expected. We are looking at considering updating Action Lists.
There is an entry in the Feature Requests portal, I suggest you go and upvote there.
