class PdfDocument in Switch 25.11
cotto
Post by cotto »
Hello and a happy new year!
I updated Switch from 2024 Fall to 25.11.
After that, Switch throws "ReferenceError: PdfDocument is not defined"
Updating the devDependencies from 'v24.0.2-final-updated.tar.gz' to 'v24.1.1-final.tar.gz' didn't solve the problem.
Is there anything I need to be aware of?
Thanks in advance!
Re: class PdfDocument in Switch 25.11
Modifying the typings file was a first and correct thing to do, but there is another thing.
The manifest.xml file in the script folder specifies the Switch version with which the script folder was created. When Switch runs a script it uses that information to choose which NodeJS version to use. What is probably happening here is that a NodeJS version is being used in which the PdfDocument class was not yet available.
The PdfDocument class was already available in 2024 Fall, but if my suspicion is correct, the script folder is older than that.
cotto
Post by cotto »
I made the recommended changes, but the problem still occurs.
I then ran a few tests.
I use the switch types in my own modules, which are also imported into the main project.
When I comment out the methods from these modules that use the PdfDocument class, the script works without the changes.
Does this mean that typing in separate modules no longer works?
Or is a special configuration required?
There are quite some settings involved in the package.json, tsconfig.json and the code itself. It may be just one of the settings that is wrong, but there is only one way to tell and that is by looking at the whole picture. Please report this to support and provide the script folder and the package so we can investigate. We will report our findings here as well so other users can learn from it.
cotto
Post by cotto »
Thanks, I have done that.
samw
Post by samw »
Providing an update on this after some initial investigation. It appears there is an issue in 25.11 which means that classes and enums provided by the Switch scripting module cannot be accessed directly from within a CommonJS module, however ES modules are not affected.
This has been logged as a bug with internal ticket number ENFS-38028 and we will address it in due course. For now the best workaround is either to use ES modules or to keep the use of provided classes and enums inside your main script file.
There is no issue with using the switch-scripting type declarations themselves in a CJS module, since they are not used at runtime – all should work as expected when you are passing instances (e.g. of Job, FlowElement etc.) to the methods provided provided by your module.
The issue comes when you need to use a class or enum that we provide via the context of the script execution, such as PdfDocument, XmlDocument, LogLevel, AccessLevel etc. So you could pass an instance of Job to a function in your module which calls Job.log(LogLevel.Info, "Hello from my CJS module") but the error will be thrown by the LogLevel.Info part (a workaround would simply be to pass "info" as LogLevel).
// To give more examples of things that will throw an error if used in a CJS module:
const pdfDoc = PdfDocument.open("path/to/file.pdf"); // ReferenceError: PdfDocument is not defined
const pageCount = PdfDocument.getNumberOfPages(); // ReferenceError: PdfDocument is not defined
const xmlDoc = XmlDocument.open() // ReferenceError: XmlDocument is not defined
const jobPath = await job.get(AccessLevel.ReadWrite); // ReferenceError: AccessLevel is not defined
await job.sendToData(Connection.Level.Warning); // ReferenceError: Connection is not defined
// And so on...
r.zegwaard
Post by r.zegwaard »
I ran into the same issue and was able to resolve it by explicitly prefixing the enum with "EnfocusSwitch."
For example:
const jobPath = await job.get(EnfocusSwitch.AccessLevel.ReadWrite);
After adding the prefix, the code worked as expected.
Next, I will experiment further with the ES module setting to see if that affects this behavior.
samw
Post by samw »
Thank you Robert, I did not think to try that. For the enums, it is mentioned in the Node.js scripting manual that these require the EnfocusSwitch. prefix, for instance for global data Scope:
Note: It is also available in global scope as EnfocusSwitch.Scope if you need to use it outside of main.js.
However this has never been my experience with previous Switch versions, frequently having using the provided classes and enums outside of main.ts/main.js. I have added this information to our bug ticket.
