imposition
DiegoAsterBR
imposition
Post by DiegoAsterBR »
I'm trying to do a 9x5 card automation and it's giving me an error in the assembly, it's adding this blank page and it's not giving me the quantity I put in the grid
erro imposition.png (32.1 KiB) Viewed 34919 times
iTAMAR MARIANO
Re: imposition
Post by iTAMAR MARIANO »
Bom dia!
Qual software você está usando para fazer essa imposição?
Olivia_Casper
Re: imposition
Post by Olivia_Casper »
I’ve seen similar behavior before with PitStop actions. Sometimes it helps to double-check the Action List order, because a small change in sequence can affect the result quite a bit. Also worth testing the steps individually to see exactly where things start behaving differently. Makes it a lot easier to track down what’s causing it.
