How to get file and folder count of the first level of a job folder
Evan
Post by Evan »
I'm looking to find a way to get the file and folder count of the first level of a Job folder to be able to assemble it back.
So if a job Folder contain 3 pdf and 2 folder, I want to be able to put "5" on my private data key (.NumFiles).
Actually "job.getFileCount()" don't work because it calculate all files excluding folder. Any Idea? Thanks!
var InputJob = job.getPath();
var Filecount = job.getFileCount();
job.setPrivateData( "Ungroup.NumFiles", Filecount);
job.sendToSingle(InputJob);
bens
Post by bens »
Hi Evan,
try this:
var theDir = new Dir( job.getPath() );
var Filecount = theDir.entryList("*", Dir.Files | Dir.Dirs | Dir.NoDotAndDotDot, Dir.Unsorted ).length;
Evan
Post by Evan »
Thanks Bens, it works.
gingrasj
Re: How to get file and folder count of the first level of a job folder
Post by gingrasj »
Hi
users dropped a folder contains pdf and indd
Folder = XX_20170524
Subfolder = xx02regu20170524
FIles = XX_001.pdf, XX_001.indd ...... etc .... XX_048.pdf
48 pdf and 25 ind = 73 files
The sub folders are used later to rename stuff
The number of Indd file aren't equal to number of PDF
1 - Ungroup all file and keep Ungroup private data as well (it's automatic)
2 - Assemble files to merge. *
3 - Merge all PDF on one newspaper
4 - Send to FTP
* I need to Assembling PDF only (48) for merge, Schema id Ungroup, number of files is Ungroup.NumFiles but that number include indd files
How to find how many indd files (25) on specific job folder ? if possible I can just job.getPrivateData("Ungroup.NumFiles") - x; on Number of files
x = number of indesign file for the ungrouped job
Jack
