Hi
I am trying to use the execute command to run a MS-Dos prompt command, but its not working...I get the error that it cant run command "XYZ"...in the error messages....but when I copy the error details and paste it in command prompt...it runs 100%.
I am running windows 7 with powerswitch 08.
Heres how I use it:
Execute Command Module settings:
Command or Path:rd
Arguments: /S /Q "C:ttest[Name.Proper]
Output:None
(So this is basically to delete a specific folder relating to the incoming file...which as I said works 100% If I do it manually)
I thought of maybe having to call the command prompt first like this:
Command or Path:c:windowssystem32cmd.exe
Arguments: rd /S /Q "C:ttest[Name.Proper]
But with this the process just hangs on executing command until it times out.
Any one maybe have any ideas as to where I am missing something? Im not 100% sure about how the execute command works...I got it working for extracting and compressing winzip files, where I just called the zip7 module....but this seems different, I assumed it automatically uses the command propmt, but Im obviously wrong about something
Any help will be fantastic!
Execute command to execute command prompt command
Clive Andrews
Have you thought of trying PSEXEC to call the command...?
http://technet.microsoft.com/en-us/sysi ... s/bb897553
I'm no great MS Techie, but have solved other issues with it...
Hi Clive
Brilliant, Thank you very much. What a awesome tool. So it does seem that calling cmd.exe directly from the Execute command tool does not work, but this works 100%.
So my execute command now looks like this:
command or path:c:PsExec.exe
Arguments(single line text with variables):
cmd /c rd /S /Q "10.10.69.117WWWWebsitesXYZ[Job.NameProper]"
Thanks again for the suggestion. Very happy that it works so well.
Kind Regards
Braam
Kind Regards
Braam
