[SOLVED] -mutator parameter rejected in PitStop Server CLI
loicaigon
Post by loicaigon »
Given documentation, youc an call an action list in CLI by using this syntax :
-mutator [path to action list]
However when trying to do so, I get an error claiming that mutator isn't a valid parameter.
Any ideas what's going on ?
Thanks in advance,
Enfocus PitStop Manager
melaniec
Re: -mutator parameter rejected in PitStop Server CLI
Post by melaniec »
Could you give the whole command you're running? Because yes, that should work...
loicaigon
Post by loicaigon »
Thanks for your concern. Indeed that suddenly worked. I can't explain myself what I did change because I feel like I used the exact same command.
Best regards,
