I'm working on a quite simple flow to sort pdf files with the help of metadata attached to it.
The XML pickup part is working fine, but the filter causes an error.
The german part means "Error in line 29 of the metadata script". I'm pretty sure that my filters (XPATHs) are right.Fehler in Zeile 29 des Skripts Metadata.Text: TypeError. 'evalToString' undefined or not a function
Also already tried it with different types of data. (INTEGER, TEXT, Boolean) Error remains the same.
Two screenshots of my flow attached.
We are using Switch 11 and maybe there is some kind of bug in the metadata-module?
Or is this error caused by the guy infront of the screen?
Thanks in advance!
Greetings
Kristoffer
