Search and replace text-file for weird characters
JimmyHartington
Post by JimmyHartington »
Hi
I have a problem with a textfile which is supplied by my customer.
And it sometimes contains some weird characters and I would like to find a way to remove them from the text-file.
I can see the weird characters in Notepad++. It is called VT in the texteditor.
See this screendump:
And here is an example of the text-file: http://d.pr/f/5Tym
Is it possible somehow to search and replace the textfile with scripting?
Kind regards Jimmy Hartington
sander
Re: Search and replace text-file for weird characters
Post by sander »
How's your scripting capabilities? This replaceLineBreak part should get you started, I use it to read a XML and replace the LF with CRLF before I inject it in my SQL database.
// Replace LF with CRLF, Prodist needs CRLF for correct parsing of e.g. addresses
var replaceLineBreak = readBody.replace(/\n/g,"\r\n");
bens
Post by bens »
VT is probably "Vertical Tab", an ancient character that is used very infrequently. Its ASCII code is 0xB (11). I don't know whether Switch regular expressions support it, but you could try searching for \xb or \x0b. Backslash x means "interpret the next part as a hexadecimal unicode point".
You may need to experiment a bit to see which syntax Switch accepts. See here for some more info: http://www.regular-expressions.info/nonprint.html
JimmyHartington
Hi
Thanks for the help with identify the character and the replace script.
I had a script I have used before to manipulate text-files.
By modifying this with the replace command I got it to work.
Here is the code:
function jobArrived( s : Switch, job : Job ){
   var extension = s.getPropertyValue("Extension");
   var tempFile = job.createPathWithExtension(extension);
   var myFile = new File(tempFile);
   var InputPath = job.getPath();
   var inputFileText = File.read(InputPath);
   var outputFileText = inputFileText.replace(/\x0b/g,"");
	myFile.open( File.WriteOnly | File.Truncate );
   myFile.writeLine(outputFileText);
   myFile.close();
   job.sendToSingle(tempFile);
   job.sendToNull(InputPath);
// Is invoked at regular intervals regardless of whether a new job arrived or not.
// The interval can be modified with s.setTimerInterval().
And here is the SwitchScript file:
http://d.pr/f/UTUv
Thanks for the help.
