Sending Emails: Define Sender
abonsey
Post by abonsey »
Hi All,
Please see viewtopic.php?f=13&t=354
I have the same requirement to be able to change the default email sender depending on the flow that is running. At the moment it's only showing the default from the Mail preferences within Switch.
It looked like it was going to be a feature request. Has it been added and I'm just missing how it's done.
Andrew
JimmyHartington
Re: Sending Emails: Define Sender
Post by JimmyHartington »
Hi Andrew
This feature could be nice.
I have implemented the service Postmark (https://postmarkapp.com) as a transactional email-sender in some of my flows.
This allows me to change the sender. Also to some of my customers emails.
But it requires some setting up in regards to DNS on the sender domain.
Post by gabrielp »
I think you can also do this with the SES Send script in switch-aws: https://github.com/open-automation/switch-aws
Iveon.Matthews
Post by Iveon.Matthews »
Hi Dominick
With the SES Send you have built for the Switch-aws Open automation project does it require an AWS account or do I just install the AWS CLI to use SES Send?
Iveon
Post by gabrielp »
AWS CLI requires an AWS account to use. You should install AWS CLI and then run
aws configure
to link your AWS account.
essexmate
Post by essexmate »
Hi, I'm currently using a VBScript to create an email which defines a sender and attaches a file. Here is the code which you can paste into SwitchScripter. When a job arrives at the script in Switch, the email is sent and the job is moved to the next flow element.
Feel free to use it, change the From, To and Cc, body text and add an attachment if required.
' Is invoked each time a new job arrives in one of the input folders for the flow element.
' The newly arrived job is passed as the second parameter.
 Function jobArrived(s, job)
Set objMessage = CreateObject("CDO.Message")
Dim fso
Set fso = CreateObject("Scripting.FileSystemObject")
'date
d = Day(date())
m = Month(date())
y = Year(date())
If len(d) = 1 Then d = "0" & d
If len(m) = 1 Then m = "0" & m
dateSubject = d & "." & m & "." & y
dateNormal = d & "-" & m & "-" & y
dateReverse = y & "-" & m & "-" & d
'email
objMessage.Subject = "Your subject goes here"
objMessage.From = "From@example.com"
objMessage.To = "To@example.com"
objMessage.Cc = "Cc@example.com; Cc2@example.com"
'If bccAddress <> "" Then objMessage.Bcc = bccAddress
emailBody = "Hello" & vbCrLf & vbCrLf _
& "This is your email body." & vbCrLf & vbCrLf _
& "And another line of email body goes here." & vbCrLf & vbCrLf _
& "Kind Regards" & vbCrLf & vbCrLf _
& "Signature line" & vbCrLf & vbCrLf
objMessage.TextBody = emailBody
objMessage.AddAttachment "\\servername\directory\"&dateReverse&"\"&dateReverse&"_example_attachment.pdf"
objMessage.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/sendusing") = 2
objMessage.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/smtpserver") = "SMTPConnectString"
objMessage.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/smtpauthenticate") = 1
objMessage.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/smtpserverport") = 25
objMessage.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/smtpusessl") = false
objMessage.Configuration.Fields.Item ("http://schemas.microsoft.com/cdo/configuration/smtpconnectiontimeout") = 15
objMessage.Configuration.Fields.Update
objMessage.Send
Set objMessage = nothing
 'Send job to next flow element
   job.sendToSingle(job.getPath())
 End Function
