Checking bleed
jslater
Checking bleed
Post by jslater »
Hello, I am setting up a workflow to QC files before they move into imposition, and one of the checks I need to perform is checking that there is enough bleed in the file. I know there's the "Select Objects Close to Page Edge" action, but it actually warns the wrong way. In other words, it throws a warning when the bleed is good instead of when it's bad. Is there a way I can set up the action list so it only warns when there is too little bleed?
enfocus
Re: Checking bleed
Post by enfocus »
If you wish that Enfocus checks why your Action List is not working, please contact us via the Support Portal:
https://www.enfocus.com/supportportal
jslater
Re: Checking bleed
Post by jslater »
Thank you, but I think I got it worked out. It's worked on all my test files, and I'll see what happens when it goes live.
