Unable to install ODBC connector on El capitan
loicaigon
Post by loicaigon »
Hi all,
I am trying to install the sql odbc connector on El Capitan and picked the appropriate dmg. However the installation fails.
I know it's out of Enfocus scope but just wanted to know if one of you guys had the same issue and if so what workaround did you use ?
Thanks in advance,
Enfocus PitStop Manager
TeLouse
Re: Unable to install ODBC connector on El capitan
Post by TeLouse »
Hi Loic, same issue here, Did you find a solution since posting?
loicaigon
Post by loicaigon »
Not really. Only "workaround" was to turn around and pick http://www.actualtech.com/
meenaloza
Post by meenaloza »
loicaigon wrote:Hi all,
Thanks in advance,
same issue here plz guide me ?
this is about mens review
loicaigon
Post by loicaigon »
I didn't try Oracle ODBC connector since switch turned to 64bits. Maybe this one will work but I just updated the Actula tech driver. The cost is really affordable and the tool just gets rid of any of thos installation issues. Definitively worth it.
scotmaria
Post by scotmaria »
loicaigon wrote: Thu Apr 07, 2016 4:50 pm Hi all,
Thanks in advance,
