Hi, I hope someone can help me figure this out.
My Hot folders are currently connected to and IP addressee that will change when I install a new prinergy Evo and Preps 8 Server. Is there a way I can universally change all my connections of the hot folders in Switch to use the new IP addressee or do I have to do it individually? All the folders will have the same name as before just different IP.
Connecting to a New IP Addressee with hot folders
Re: Connecting to a New IP Addressee with hot folders
How about replacing the name in your switch backing folder\flows\Flow.xml, that might work
Thanks for you response.
I went into my backing folders and I have 108 flow xml files. Should their be one universal folder or should I update all these individually?
Again, this might work but I did not do it before so test with one test flow first.
You can 'batch' find/replace from within a folder with notepad++ so you don't have to open each individually.
