Not allowing unknown Spots, except some
cwswitch
Post by cwswitch »
I'd like to achieve this through preflight or an action:
Jobs with spot colours = Pass
Jobs with unknown colours [knife, cut, don't print, day glo pink, card goes here .... ] = Fail
ALTHOUGH..
I'd like to fail every unknown colour a designer could put in their art - without having to form a list, which could get exhausting
But then, I'd like to allow colours we know what to do with, such as EyeCut, EyeCrease, which are interpreted correctly by our workflows
cwswitch
Re: Not allowing unknown Spots, except some
Post by cwswitch »
Perhaps this phrases the question more clearly:
All normal spot colours + some named spot colours I choose to have = pass
Any named spot that is not in the Pantone library, and is not in my white list = fail
E.g
PANTONE 485 C + EyeCut = pass (because EyeCut is in my white list and I know what to do with it)
PANTONE 485 C + Perforate = fail (because the designer is inventing colours to mean something that my workflow can't interpret (yet)
loicaigon
Post by loicaigon »
Here is a proposal that seems to do the job:
The idea is to use Regular Expression. The hard part is to "reverse" the expression so it looks at anything that do not match specific strings:
^((?!PANTONE|EyeCut).)*$
Checking for SPOTs not being PANTONE… nor EyeCut.eal.zip
(1.88 KiB) Downloaded 64186 times
cwswitch
Post by cwswitch »
That's great and very easy to edit to my needs. - Thanks you very much!
One thing .. It flags "DeviceN" when present and I'd rather it didn't - example here
loicaigon
Post by loicaigon »
Voilà…
Checking for SPOTs not being PANTONE… nor EyeCut.eal 2.zip
(1.96 KiB) Downloaded 63834 times
cwswitch
Post by cwswitch »
Wow! I'd like to buy you a beer
Out of interest, how did you know to look for "Shading Objects"?
I had been trying to search for "DeviceN", then add a NOT, but it had not worked.
loicaigon
Post by loicaigon »
Well beers certainly accepted !
Regarding to shading objects, I just needed to check what the object actually was using inspector. Once I could see it was shading objects it wasn't hard to exclude them from selection.
